Browse Forums General Discussion 1 Apr 19, 2011 9:27 pm After we got council approval we used to drive past out block to see if the standard fence and portaloo were put on our land, ready for construction to start. The slab is about to be poured (piers were poured last week) and still no fence. Is this normal? Secondly, if someone is injured on our land, as in a random person walking on our block, are we liable or is the builder? Technically they would be trespassing but with vacant blocks around us I assume people would walk through the site on occasion. I'm a bit surprised that there's no fence, particularly as the site is on a 3m sloping block with a 3-tiered slab. Now that the pipes are sticking out of the ground I'm also concerned about potential vandalism. while there isn't anyone living in our street yet, the suburb is already established in earlier releases and the local teenagers are known for causing havoc in their boredom. Land at Chermside At tender stage Re: Is a fence around a building block compulsory? 3Apr 19, 2011 9:49 pm Amongst your site costs check to see if they have included a cost for temporary fencing. Most councils require temporary fencing to be constructed. When I built with DFH a couple of years ago, the temporary fencing was not put up until the slab was poured. I assumed this was so that they could get easier access to the block. House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: Is a fence around a building block compulsory? 5Apr 20, 2011 7:29 am ^ What deb said. As long as you haven't been charged for it, it's not your problem. Re: Is a fence around a building block compulsory? 6Apr 20, 2011 9:39 am We never had any fencing. And When your house is being constructed the site is the responsibility of the builder...YOU are not even meant to be on site. So anyone falling in a hole or tripping over the slab will be suing the pants off your builder not you personally. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Is a fence around a building block compulsory? 7Apr 20, 2011 2:35 pm Ours turned up around the same time the frame delivery started. Not there one day,there the next. Was still there on monday but will be gone today as PCI and handover is tommorrow. Hell Yeah!! Re: Is a fence around a building block compulsory? 8May 01, 2011 7:51 pm Yep. Site must be fenced. Std temp fencing. And the site must be "bunded". This means all the run-off on the site must not go on footpaths, roads, stormwater etc. Bales of hay and plastic etc on the low boundaries. Also most local gov'ts require a wheel wash so that all vehicles can be hosed off before they leave the site. Also toilet (and safety shower, but ready access hose will do). Always surprised how often it is not done. The builders resp not yours. Paul You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12894 |
