Browse Forums General Discussion 1 Apr 11, 2011 8:04 pm We are in a situation with a retaining wall and would like all of your advise as to whether you think our objection will be successful or not? We are close to completion of our build in a new estate (Campbelltown Council, NSW). The back of our land drops about 1.5m from the rear of the building to the rear boundary (about 12m). There is already a wooden sleeper retaining wall (2m high) on the back and it doesn't have enough height to accommodate the leveling of our yard (and our neighbors). Just recently the developer intends on putting about a dozen duplexes to the rear of the property and we placed an objection to the DA around increasing the height of the retaining wall as I believe that failure to increase the heights of all the retaining walls will result in inconsistent heights, ugly fencing, erosion and drainage problems. There is only one developer in the estate and they are the same ones that have built our house. In all your worldly opinions do you think that this objection will succeed or fail? As we really need to start planning for fencing and building our own retaining wall if required....... Interested in your thoughts!!! Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Have you ever lodged a DA Objection and succeeded? 2Apr 12, 2011 11:11 pm DAs in NSW are assessed on the provisions of Section 79 (c) of the Environmental Planning and Assessment Act 1979 (basically does the proposed development have environmental impacts that are unacceptable). For an objection to carry weight generally, the negative environmental impact of the development must be identified. Saying that the development will have a negative impact is not enough (in my opinion) without evidence. Perhaps you should ask to see prelim engineering details of how stormwater will be managed. This may lead to a redesign of the wall? Otherwise, it sounds to me like you are up against it. These are just my thoughts though. Not legal advice or anything that should be relied on! Re: Have you ever lodged a DA Objection and succeeded? 3Apr 13, 2011 10:11 pm Thanks Large... this gives me some insight into the process so that I am aware. I think you are right in that it may be difficult to justify our objection but thought that it may as well be worth a try. As submissions were due to close yesterday I would expect that it may be a little too late to ask for any more information on this - however i will keep you updated with what actually happens. Thanks again for your insight as it has helped set our expectations on what is likely to happen. Cheers Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Re: Have you ever lodged a DA Objection and succeeded? 4Apr 15, 2011 9:40 pm if there is only 1 objection they dont usually care too much, they have so many DAs to deal with it, unless you speak to the head of the dept...you might be able to sway them Make your own Organic Vegetable Patch, Learn How to Build a Pergola http://www.homestyledesign.com.au Re: Have you ever lodged a DA Objection and succeeded? 5Apr 16, 2011 6:35 am I did ask my neighbours to put it objections so there should be at least 2-3 objections made.. it is in a greenfields development so hope that may have some influence into the outcome... it isn't looking too good however as when we went out there yesterday the developer has already started putting up the fencing above the existing retaining wall... which would mean that it would make it difficult to raise it even if we wanted to do it ourselves!!!!! Project History Deposit - 20/4/2010 Land Settled - 20/8/2010 Council - 30/9/2010 Slab - 17/11/2010 Bricks - 28/01/2011 Roof - 5/02/2011 Gyprock - 4/03/2011 Hi, Appreciate any recommendations for town planners or advisors who can help assist to assess and draft an objection to a neighbour’s development in Northern Beaches.… 0 3634 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39753 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10352 |
