So basically they just told us to clean up the mould and it should be okay.
Absolute BS! Your dh is correct and you are very wise not letting it end there. How stupid does this builder think you are?
Browse Forums General Discussion Eeeek - mould found in our wardrobe - 6 month old house!! 21Apr 02, 2011 12:52 pm n&n02 So basically they just told us to clean up the mould and it should be okay. Absolute BS! Your dh is correct and you are very wise not letting it end there. How stupid does this builder think you are? Re: Eeeek - mould found in our wardrobe - 6 month old house! 24Apr 04, 2011 8:26 pm We found mold in our house on Saturday too. It's still being built and the ceiling and cornice in the ensuite roof is covered in it. Our SS actually told our neighbours (he uses our house to show them through as we are building the same plan and theirs is behind ours) they just wipe it with bleach prior to PCI and paint over it Surely, if there is dampness in the roof the mold will just reoccur and the roof plaster and whatever else in the roof is damp, cracked tiles etc ought to be replaced? This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28571 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 16070 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3151 |
