Browse Forums General Discussion 1 Feb 27, 2011 2:42 pm Hi there, After some advise and feedback on the floor plan we've trown together below. Bare in mind we've thrown this together quickly, it's our first draft I guess! Looking forward to all the feedback, suggestions and ideas! Sorry it's not the clearest picture .... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Jem's Custom build - viewtopic.php?f=31&t=58630 Re: House Floor plans... 2Feb 27, 2011 3:18 pm Hi Here are a few thoughts, I hope You find them helpful. They are fairly general as I don't know how big your block is and how flexible you are to change. I think your family room, dining room and kitchen are going to fairly gloomy facing south and with such a big veranda. I would swap the WIR and Ensuite so you can have a North Facing Window in the Ensuite rather than a West facing Window. Don't have a West facing Window in the Living Room as that would make it unbearable hot on Summer Evenings. With Bathroom and Laundry at the opposite end of the house you will need instantaneous hot water for both ends of the house or running water for several minutes to get hot water in the Kitchen and En Suite, if the hot water service is outside the laundry. Regards The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: House Floor plans... 3Feb 28, 2011 6:08 am change the master bed door to open the other way for more privacy and I would want a closed off room..maybe the living room, cos all open plan with all those bedrooms = all those kids would drive me insane. there is no where to hide. while you are in the kitchen you can hear people in the family room and the living room..arrgh!! and you can only have 1 tv as it would be too noisy. if you have a 'tv room' closed off in the living room, you can then have playstation there, or a tv free room and playstatiom in study, if it is a family home, it needs areas for families to chill out it. reading, homework, listening to the news, music, playstation etc Re: House Floor plans... 4Feb 28, 2011 3:33 pm Hi there, Thanks for the feedback. The house will be built on roughly an acre and I am quite open to new ideas and change. Maybe we could swap the living room and study some how. We couls them make the veranda small letting more natural light in and close of the lounge for a bit of piece and quiet? What do you think? Would love to hear other suggestions! TIA Jem's Custom build - viewtopic.php?f=31&t=58630 Re: House Floor plans... 5Feb 28, 2011 3:43 pm If I had an acre I would look to go for a passive solar house with a lot of the more important rooms on the north side. It would have a long north facing roof for solar panels and solar hot water. If you are thinking about changing your design the following link might give you a few thoughts: http://www.anewhouse.com.au/?p=326 Its the first of three posts that shows how I went about designing a floor plan for the house we built. Regards The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: House Floor plans... 6Feb 28, 2011 4:32 pm Swap your bathroom and toilet around so you have better access to the loo from the laundry & outside. saves having muddy footprints up the hall. Plus bed 2 will not get the noise from the toilet flushing. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: House Floor plans... 7Feb 28, 2011 5:40 pm we have an acre too!!! if you can follow bashworths advice. have most of your living north, so you get winter sun and warmth. very few west facing windows and the alfresco north too. (if you can. might be a road north) Re: House Floor plans... 10Mar 02, 2011 7:00 am Our block is in a court of acre blocks. The front of our house which will face the road is facing to the north. We want to have all the living opening out onto the backyard so not sure what we should do. We're in Vic too and will need an air con at least. Jem's Custom build - viewtopic.php?f=31&t=58630 Re: House Floor plans... 11Mar 02, 2011 3:36 pm If think you might go down the path of facing rooms to the North one way around is to place the house more to the back of the block so you can look at a big front yard. The distance will make the house seem more private and you can always plant a hedge. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17503 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6882 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16537 |
