Browse Forums General Discussion 1 Feb 15, 2011 6:17 pm I was going to have bottled gas but am now seriously thinking of changing to natural gas, since I found out it is available in my area. Given that I now won't have to worry about running out of gas, I am wondering if a heat pump hot water system will be worth the approx $2500 extra it is going to cost? I am a complete newbie when it comes to both gas and heat pumps so hope that someone will share their experience. Re: Are heat pump hot water systems worth the money? 3Feb 20, 2011 7:57 pm From my experience in commercial application, healthcare. southern Australia Cheapest to most expensive Natural gas boosted solar hot water heat pumps LPG boosted solar Natural gas LPG Electric That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor 10 1613 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14820 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20659 |
