Browse Forums General Discussion Re: Simonds home Truganina collapses after storm 2Feb 13, 2011 9:41 pm Based on a tip off I went down to the lot and didn't find any timber left except for bricks and a window frame. From what I was told the house was up to brick stage when the whole house collapsed to one side. The Simonds sign had a big "KEEP OUT DANGER" and someone cheekily wrote "unlucky" under client. Re: Simonds home Truganina collapses after storm 3Feb 14, 2011 11:41 am I'm building with Simonds at the moment. Our house (in SE Melb) has basically stalled as all the tradies have been put onto fixing storm damage. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7815 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6845 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10472 |
