Browse Forums General Discussion Re: Sinkhole formed in backyard - who is liable? 2Feb 07, 2011 9:20 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Sinkhole formed in backyard - who is liable? 3Feb 07, 2011 9:44 pm Where you are coming from is where you are going to... Re: Sinkhole formed in backyard - who is liable? 5Sep 15, 2023 5:22 pm mortgage2009 Hi all Sorry for not posting an update to this, we've been overseas and I've changed jobs, which has taken over my life. Ok, well we ended up contacting the council, yarra water, and the developer of our estate (Dennis) over and over and over again. It ended up wit Dennis to deal with, and we had a few people come out to check it out (3mths later...). According to them, there were a "couple" of blocks on the estate that also had some "minor" sinkhole problems. Developer and eavesment line contractors came out and agreed that due to the huge amount of rainfall since Feb, the compacting of the soil above the piping was never going to hold the waters weight many times over in such a short period of time. They cannto compact it to heavily or there is a risk the pipes will crack. Blah Blah So the hole ended up being filled with soil and we've had no problems since. I did find out via our neighbours that almost evey second house in our stage has had sinkhole problems (some across the entire back fence line), and some poor couple on the corner spent $4k on decking and landscaping which fell.... So clearly we didn't have it that bad compared to others. Contact me if you need specific details Hi, Thank you for sharing this, you probably won’t believe someone me will have the same issue as your in 2023, 12 years later. Could you please let me know who would actually worth to contact? My house like 5 years old and same as your has a sink hole next to the council pipe. It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9369 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25281 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 14239 |
