Browse Forums General Discussion 1 Feb 03, 2011 9:03 am Hi, I have a 1950's double-brick house with internal walls made from standard 110mm wide brick with 13mm render per side (total width of internal wall = 136mm). However, the rendered bathroom walls on the second floor measure about 100mm wide. Measuring under the skirting board of the bathroom wall as it continues into the hall (carpet removed and polished floor now) I measure the unrendered part of the wall as about 76mm wide. I've looked at the Austral site and I can't find any bricks that are 76mm wide. So my question is, how on earth were these thin walls made? Does anybody know if there is such a thing as a narrow brick? I note that 76mm is about 3 inches, maybe that was a standard once? Were thin walls like this common for bathrooms? Were standard bricks layed on their side? Final thought is that this wall was probably unsupported on the floor beneath originally, so maybe they had to make it lighter? Really appreciate any ideas or experiences people have had. Thanks. Re: Bathroom walls mysterious width 2Feb 03, 2011 1:25 pm I really have no idea as I am in the east where they don't normally do double bricks, and my house is BV. But it does strike me that 76mm is the height of our bricks. could they have laid the bricks sideways?? or, perhaps they make special skinny bricks for thin walls? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Bathroom walls mysterious width 3Feb 03, 2011 1:56 pm Although its unusual these days to see bricks laid on edge it wasn't always the case. There is even a special cavity wall technique for bricks laid on edge called Rat Trap see the link. Its quite a good bond for brick retaining walls as you can add reinforcement. http://www.gharexpert.com/a/ashishbatra ... ond_0.aspx The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Bathroom walls mysterious width 4Feb 05, 2011 8:09 am Thanks. I'll try and get in the roof to see if the top of the wall is visible. Maybe the mystery will be revealed. Re: Bathroom walls mysterious width 5Feb 14, 2011 12:49 pm Brick on edge is very common for internal walls during the fifties because of the obvious cost savings Thanks again for this information. If you do hear anything different, would be great to know 4 8330 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4223 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6144 |
