Browse Forums General Discussion 1 Jan 30, 2011 9:08 pm Have house in inner Brisbane and we are looking at options to build in under. The house is a post war four bed one bath upstairs and already has two nice decks (front and back). We are about 300mm off legal height under. Investigating digging down rather than raising as I think the raise will be too expensive considering it will also include having to build two new decks etc etc. Given the number of houses in Brisbane just off legal I would be surprised if others haven't thought of this also (though we didn't find any other topics using the search!). Queries are - anyone tried this approach? If so how did you deal with the waterproofing problem? My initial thoughts would be to excavate all under house down 500mm (approx allowing for 200mm slab) and repost where necessary including pouring new footings. After this pour a new slab, besser blocks one or two high and have waterproofed, with the last step being installing larger stormwater drains to take as much surface water as possible around the perimetre. Any advice out there? We are investigating first before getting plans drawn. Cheers. Re: Going down instead of raising 2Jan 31, 2011 7:42 am Does it matter since its obviously an old house? I can understand that it would be an issue for a new place. Someone else was looking at this in this thread viewtopic.php?f=1&t=37318 Re: Going down instead of raising 3Jan 31, 2011 4:58 pm Hi I work in the drainage industry and the best piece of advice I can give you is make sure that if you go close to the level of the sewers don't have any toilets basins etc in the basement. If you get a blockage these become the lowest point and overflow. I have seen too many flooded basements because of this! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Going down instead of raising 4Feb 01, 2011 3:56 pm I'm not overly worried about sewerage at this stage. We can easily get to the sewer line and were not planning on dropping the area the bathroom is proposed to go in - only the main living area and a spare bedroom. Anyone else got any other ideas on this one or have actually achieved this? Or has everyone just gone the raise and build in option? Re: Going down instead of raising 5Feb 01, 2011 5:14 pm Be very careful when going down - if you hit unexpected soils or rock it could cost a fortune in extra excavation fees and so on. I suggest getting a Geotechnical engineers report before anything else to make sure it is feasible to build down. AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6277 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105553 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 |
