Browse Forums General Discussion Re: Double glazed windows 2Dec 12, 2007 6:45 pm Vinyl and uPVC are the same thing.
PVC = poly vinyl chloride u = unplasticised (that is, rigid) PVC on it's own is rigid. By putting plasticisers in it can be made flexible. Demolition August 2009, Construction Started September 2009, Completed December 2010 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 7678 ![]() DIY, Home Maintenance & Repair You could use thermal imaging camera to detect water pipes. You should be able to get a low end version of it for around $250 from AliExpress. 2 5491 Yes, you have a thermal bridge there which needs to be insulated in one way or another. I would simply glue some R2.5 batts there, you should be able to fit them. 2 1408 |
