Browse Forums General Discussion 1 Jan 27, 2011 8:48 pm The builder is providing 160lt tank with one solar panel with gas heating. I have heard that if one installs a 160lt tank with 1 panel we may run out of warm water, and we need to have dual pipe runing otherwise it can reduce the water pressure if hot water is opened at 2 places. Could someone please guide me with this. How to have equal pressure if taps opened simultaneously and do i need a 350lt tank with 2 solar panels. Cheers Re: Solar water heating and tank 2Jan 27, 2011 8:54 pm We have gas-boosted solar, and have never run out of hot water. We turned the boost switch on the day we moved in, and have left it on since. Our gas-boost part is a Rinnai Infinity box. Judie Re: Solar water heating and tank 3Jan 27, 2011 10:44 pm As Judie said, if it's gas-boosted, you can't run out of hot water. We went for a larger tank - can't remember the size now, but I think it's 215L - with two panels, with the idea of getting the maximum "free" hot water possible for our family of five. Our gas bills are teeny-tiny in summer... 350L sounds like overkill. I'm not sure why water pressure would be an issue, regardless of tank size. Any plumbers care to enlighten us? Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 |
