Browse Forums General Discussion Re: portal shed used for a house 2Jan 26, 2011 2:12 pm It does depend on your council regulations, but the biggest areas of concern in conversion are: -Insulation - you have to make sure you can upgrade to the right level of insulation for your area - This should be relatively easy -Light and Ventilation - There are minimum levels of light and ventilation required so you may have to add in windows etc. -Waterproofing - When constructing a house pad a water poof membrane is put under slab to stop damp rising through the slab. Sheds do not usually have this done, so it would have to be addressed. This is usually the biggest headache with conversions as councils are very particular with this. Nathan Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5416 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3428 |
