Browse Forums General Discussion 1 Jan 20, 2011 10:21 pm Hi, I need to lay some pavers about 200mm above some stormwater pipes. I have a heap of sydney sand that I need to use up so I was hoping to use this as the base. Can anyone tell me if I have to surround the stormwater with blue metal or is it ok to pack it with the sand. Any advice would be appreciated. Cheers Re: Can u help with advice on laying pavers over stormwater 2Jan 21, 2011 9:38 am Check with your local council regarding minimum depth and what you need to surround it in. I think water is 400mm depth min and elec is 600mm depth min. not sure about surrounding soil/material though Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 3243 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 2139 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 760 |
