Browse Forums General Discussion 1 Jan 10, 2011 12:13 pm Hi all. We are renovating our house this year and are considering plastering the garage. There's a door from the garage into the house and I've noticed on the house plans that door is specifically marked as being fire proof. Does that mean we need to use fire proof plaster? What is the cost of a fireproof plastering job versus a regular plastering job (garage is about 16 sqm)? Thanks. Re: Fireproof plastering for a garage? 2Jan 10, 2011 12:20 pm Check with the builder as standard plasterboard maybe already be 2 or 4 hours fire rated. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Fireproof plastering for a garage? 3Jan 10, 2011 4:26 pm What is the existing structure of the garage? Is it brick you are plastering? Are you in an multi unit complex? Is the Garage on the Boundary? Generally you only need fireproofing within 900mm of the boundary. If it is brick it will have the necessary fire rating and the plastering over the top is not required to be anything special. Nathan Re: Fireproof plastering for a garage? 4Jan 10, 2011 8:05 pm Thanks for the quick replies. The garage is brick and is about 2 meters from the boundary so it would seem we do not need any specific fireproofing. I'll take it up further with our builder when we get one! Thanks again. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17203 |
