Browse Forums General Discussion 1 Jan 07, 2011 9:55 pm So, I have just arrived home and seen the colour of what will be our retaining wall out of treated pine and steel rsj, however I am not loving the look of treated pine, I think I want to paint or stain them however tomorrow they will be started to be installed, I have left it too late and not sure what options I have. Is it okay to paint once they have been assembled, this way I will save paint as the back will be covered in dirt due to the retaining wall purpose, hmm.. suggestions please!! Thank you, Laney, Our Build Thread: viewtopic.php?f=31&t=30685 Re: painting treated pinE 2Jan 08, 2011 12:07 am I would not recommend paint for the situation you describe. Moisture coming in from the back and then being evaporated o a hot day is too extreme a situation for any paint. The best thing would be a stain or decking oil type finish. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: painting treated pinE 3Jan 08, 2011 7:39 am A hint on staining TP from a previous thread. Wet the TP and once it appears dry apply the stain. Because the TP has absorbed moisture and only the surface layers are dry only a fraction of the amount of stain is required. Still gives the same finish. Haven't tried it myself, just stole the idea from someone elses post. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: painting treated pinE 4Jan 08, 2011 5:44 pm You could perhaps clad it in blueboard and use a render effect paint. More cost (and a bit of skill required), but it would look good. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52857 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10972 |
