Browse Forums General Discussion 1 Dec 30, 2010 11:06 pm A question for those with large hardwood flooring areas. What do you find to be the quickest way to clean (sweep and mop) your floors? Re: Quickest way to clean 300sqm+ of hardwood flooring? 2Dec 31, 2010 6:28 am I use a combination broom/mop. The broom part is a big fluffy head that I use every day. The mop part is a microfibre material head that you dampen and run over the floor. I do this once per week. Occasionally I get out the vacuum, however this is only for major spills. Re: Quickest way to clean 300sqm+ of hardwood flooring? 3Dec 31, 2010 8:19 am I think I'm the same as upsydaisy. I use a microfibre static type broom (with a square head) most of the time. Both sabco and oates clean make ones that you can buy at major retailers. It also comes with a mop head but I haven't used that yet (only been in the house a week). Re: Quickest way to clean 300sqm+ of hardwood flooring? 4Dec 31, 2010 8:31 am Quick vacuum then dampened Oates microfibre pad (the blue one). Do the whole floor once a week and under dining table and near entrance once a day (or so). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Quickest way to clean 300sqm+ of hardwood flooring? 5Dec 31, 2010 1:31 pm Thank you for your responses. Does anyone know where I could get an extra wide mop handle thinggy in order to speed up the process? Re: Quickest way to clean 300sqm+ of hardwood flooring? 6Dec 31, 2010 2:49 pm although we are having tiled floor have you thought of buying a romba? its my house warming pressies to myself - hopefully ill only have monthly cleans Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: Quickest way to clean 300sqm+ of hardwood flooring? 8Dec 31, 2010 4:41 pm I use an Enjo dust mitt with the mop frequently and only every couple of weeks do I use the wet mitt. Re: Quickest way to clean 300sqm+ of hardwood flooring? 9Dec 31, 2010 5:25 pm I use a dry Sabco Bulldozer dust control mop - 60cm wide, shaggy orange for sweeping every few days. Only takes 10 minutes for the entire house (bedrooms are carpeted). I use a damp Sabco Super Swish microfibre mop for spot cleaning and general cleaning once a week. Keeping our new timber floors has proved to be soooooo easy! Re: Quickest way to clean 300sqm+ of hardwood flooring? 10Jan 04, 2011 1:19 pm Trinity I use a dry Sabco Bulldozer dust control mop - 60cm wide, shaggy orange for sweeping every few days. Only takes 10 minutes for the entire house (bedrooms are carpeted). I use a damp Sabco Super Swish microfibre mop for spot cleaning and general cleaning once a week. Keeping our new timber floors has proved to be soooooo easy! I love the sound of that! is 60cm the widest one available? Re: Quickest way to clean 300sqm+ of hardwood flooring? 11Jan 04, 2011 10:19 pm It's the widest dust mop I could find in my local Bunnings. I have seen cleaners using wider dust mops in shopping centres though . I think they're called scissor mops. Probably a bit over the top for residential use. I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1215 Hi All. I'm currently resurfacing the hardwood floors and when removing the old layers that there's a long dark line running across the boards. Does anyone know what or… 0 12770 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4539 |
