build to boundary guttering overhang's neighbours property
As a consequence, the guttering is overhanging the neighbour's property.
Draughting plans show a 150mm setback allowance was required.
Structural engineers were engaged
The site was laid out by suryeyers.
A private building certifier was used.
The property was inspected and passed at:
Foundation stage, excavation stage, slab stage, frame stage and final stage.
A final Inspection Certificate was issued.
The builder says everything was done using professional people, so he can only go off what they have provided him and that a Final Certificate of Occupancy has been given by the Certifier.
I'm not sure where I should go from here.
If its the surveyor who caused the problem its up to the builder to claim the cost of the remedy from the surveyor.
so when it over flows it drains onto your gutter? Totally illegal.
5
Yes, get a builder, make sure he is experienced and a registered building practitioner
30/08/2023
13
In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection.
14/09/2023
4
Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges.
