Browse Forums General Discussion 1 Dec 15, 2010 7:40 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: hot water system 4Dec 15, 2010 10:46 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: hot water system 8Dec 17, 2010 8:54 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: hot water system 14Dec 26, 2010 11:58 pm You are spot on with the gas boost solar hot water system being the most efficient to run, yet its only econmical if you have gas (natural) running into your home. If you dont you can consider a electric booster solar hot water system or if you dont have enough north facing roof for solar hot water you may need to consider a heat pump. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14207 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2672 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20351 |
