Browse Forums General Discussion 1 Dec 06, 2010 6:36 am as the title says our hot water system died last night. We need hot water quickly - showers etc..... having never even remotely looked at hot water systems I have no idea what is out there, choices, good bad etc. any threads anyone can point me to or experiences you can share. after a good system, energy efficient ( is that possible) that is reasonably priced and will provide good hot water reliably. who are the main players worth investigating, anything we should be wary of I need my shower!! renobeginner edited to say: if this thread belongs in a particular forum please let me know! thanks Re: Hot water system died last night - HELP 2Dec 06, 2010 8:13 am What sort of system do you currently have-gas, solar, electric or chip heater? If you are moving from one type to another, keep in mind the extra works that will be needed to make the change to an alternate system happen-pipework, wiring, mountings amongst other things. Re: Hot water system died last night - HELP 3Dec 06, 2010 11:11 am the usual gas standard one. Reece system, out the side of the house. everytime you turn on the hot water tap, all we get is rusty ( very rusty red) water. Yuck Re: Hot water system died last night - HELP 4Dec 06, 2010 12:50 pm Seeing you've already got gas, and you have to replace the unit so you have hot water ASAP, go with another gas unit. All the fittings are there, makes for a cheap changeover (depending on the cost of the unit) Re: Hot water system died last night - HELP 5Dec 06, 2010 4:37 pm oops I meant Rheem (where is the blush Icon) the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14178 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2594 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20336 |
