Browse Forums General Discussion 1 Dec 05, 2010 10:25 pm Hi We have just finished building and have been in for about 4 wks Can anyone tell me how long the metally taste in the water in new pipes is suppose to last At the moment anything we drink etc has to go through a brita jug I have, as the water is so bad we cant drink it, you can even smell it in the coffee if you dont use the jug. There are only 2 of us in this 4brm 2 bth house but both showers get used every day and we also have solar hot water, dont know if that makes any difference. Thanks from someone how would like to use her tap to fill the kettle My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: NEW WATER PIPES 3Dec 06, 2010 9:53 am 1sthome Might be good to flush the pipes if you haven't done so already. It's a bit of a waste of water but can be useful to clear them out initally. Did you use copper or plastic pipes? Hi 1sthome Yep did that after about a week of being in there as the water was making the sugar in drinks all clump together, so I rang there water board and thats what they told me to do, and that fixed that problem. Thought the metally taste would just go, but it hasnt. No sure what pipes they used. I would say from the taste it might be copper My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: NEW WATER PIPES 4Dec 06, 2010 12:57 pm The pipe from the main to the meter will be copper. The pipe from the meter to you house may be copper or plastic. Its about 50/50 the pipe from the point of entry of your house and throughout the house will most likely be plastic. You may have a slight build up of "copper corrosion" due to the line not being used a lot for an extended period of time. This can also cause the water to turn blue/green. To get rid of it you can run your taps for a while and test the water every now and then to see how it tastes. **IMPORTANT DISCLAIMER** PLEASE!!!!!!!!!!! Catch the water in a bucket/s and re use it on your garden. You could even pour it into you water tank and use it later. Depending on where you are, it may just be bad water as well. The first thing I went and bought for our new kitchen was an under bench filter. Even though we are building on the same block of land, I'm not going to chance it as the water here has been average at best. I have also purchased filter to use in line before our HWS so that we get as little crud build up as possible Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10891 4 5152 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5776 |
