Browse Forums General Discussion Re: Removing a fire place 4Dec 02, 2010 8:28 pm I have removed one, in my old place, about 4 years ago. It was a double-brick house, with floorboards. After removing the fireplace, I bricked up the cavity, rendered with mortar until approx 2-3mm under the wall surface. Then apply plaster, and sand, sand, sand. Use a long flat object with sand paper taped to it. This way the finished surface is smooth (no lumps & bumps). Seal the plaster, then paint. For the floor, the length of the my wall wasn't very long. So, I removed about four rows of floorboards, and put in new ones. Stained to match existing floorboard. I wouldn't say it's very hard, but it's not for the faint-hearted. Chris We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5356 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3900 Not back peddling at all. You seem to have issues with comprehension my friend. Guy fcked up, he's considering being dishonest with his bank and hiding it. It will end… 21 14346 |
