Browse Forums General Discussion 1 Nov 22, 2010 7:46 am Hi, I recently changed some light fittings in my house, I did this by myself and I just read that this is actually illegal and can caused my insurance void. Is it possible to call acertified electrician to inspect and make them a certified electrical work? Has anyone done this before? Thanks. Tim Re: DIY installing lights, can it be certified? 3Nov 22, 2010 1:58 pm Did you actually do(or touch) the wiring or was it a simple light fitting. I don't see any reason why you can not pay some one to check and inspect. However they may charge you more to inspected it. Re: DIY installing lights, can it be certified? 4Nov 22, 2010 8:53 pm B STAR Did you actually do(or touch) the wiring or was it a simple light fitting. I don't see any reason why you can not pay some one to check and inspect. However they may charge you more to inspected it. I took off the (basic) light fitting and put the oyster one. I also did the one in the kitchen and installed the kitchen spot lights. So yes, I touched the wiring when I did it. I am not electrician but I understand the basic of wiring. I am just worried if the insurance will void if anything happen to the house. Re: DIY installing lights, can it be certified? 5Nov 22, 2010 9:22 pm Id love to know too. Jason Building a modified Platinum MKII with Blueprint Homes. House Plan Contracts Signed: 18/10/2010 Prestart 21/10/2010 Sandpad: 14/1/2011 Slabbed: 27/1/2011 Brickwork: 15/2/2011 Roof: 18/3/2011 Re: DIY installing lights, can it be certified? 6Nov 23, 2010 8:35 am I would say it would only make your insurance void if it was found that your DIY wiring was the cause of the fire.... I doubt the insurance company could get out of a payout from... say a storm because this wiring over here has no corresponding compliance certificate. None the less you have technically broken the law by changing the light fitting..... bad boy now go sit in the corner Cheers Cozmo ______________________________ Building a PD Heywood 29 http://fromevetoeternity.blogspot.com/ 0 4972 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6694 Ask yourself if the insurance company will be aware of the Reno. 4 7360 |
