Browse Forums General Discussion 1 Oct 30, 2010 11:14 am Hi all, We have increased our living area/kitchen,entry to 32c. How does this affect doorways,the look etc,do they need bulkheads or what do you do. Pictures would be wonderful cheers ♥ Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Ceiling height verses door height 2Oct 30, 2010 12:17 pm Some people increase the door and window heights if they have higher ceilings, some do not. Kerry-ann, do a search - this topic has been discussed at length many previous times. Re: Ceiling height verses door height 3Oct 30, 2010 7:11 pm Hi & thanks for that. I did a search & its a mine field of threads & posts. Still hoping some-one has some pictues to show,PRETTY PLEASE Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Ceiling height verses door height 4Oct 30, 2010 10:03 pm Look at my blog there are completed house photos, we have 2.7 ceilings and used standard hieghtdoors. Only the glass sliders are higher. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Ceiling height verses door height 5Oct 30, 2010 10:21 pm take2 - just had to say. Gorgeous house. I really like your choices. Great blog, thanks for sharing. Rebecca Custom Build with Kersbrook Constructions - SA https://forum.homeone.com.au/viewtopic.php?f=31&t=37762 Current Status: Handover on Thursday!!!!!!!!!!!!!!!!! Re: Ceiling height verses door height 6Oct 31, 2010 7:00 am We have ceiling heights of 2590mm with doors in the main areas of the house at 2340mm but the doors in the rear hallway are still the standard door height of 2040mm. Check out my thread. I'll call past tonight and see if I can get photos of the actual doors so not just random photos!! Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Ceiling height verses door height 7Oct 31, 2010 5:23 pm sleven We have ceiling heights of 2590mm with doors in the main areas of the house at 2340mm but the doors in the rear hallway are still the standard door height of 2040mm. Check out my thread. I'll call past tonight and see if I can get photos of the actual doors so not just random photos!! Hi,thank-you for that,would be great Sleven. Thank-you to the others for answering. cheers Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Ceiling height verses door height 8Oct 31, 2010 6:33 pm Hi Kerry-ann I'm not sure if this helps you out, but we have 2700mm ceilings with 2340 doors and bulkheads. My personal opinion is that if you can afford them, the higher doors look great and they give a feeling of spaciousness. I love ours. Good Luck Julie-anne Re: Ceiling height verses door height 9Nov 07, 2010 3:27 pm I haven't got any pics right now, but we have 2700mm ceilings and 2340mm doors. As julie-ann said, we love ours and are glad we did it. We increased the height of all the doors including the wardrobe doors. This means we can fully utilise the extra height more efficiently for storage rather than having a big blank area above the shelf that you can't access easily because the door is lower if that makes sense. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Ceiling height verses door height 10Nov 07, 2010 9:53 pm Thanks Ladies, Julie-Anne i'm sorry i thought i thanked you before for your photo's,which look lovely by the way. cheers Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10665 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15980 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 |
