Browse Forums General Discussion 1 Oct 12, 2010 4:06 pm Not sure if it helps, but a "Standard spec" doesn't really exist Having said that, all it needs to be is a detailed list of the materials and fitting you will be using to build the house. If you like, I can give you a copy of ours (minus our details and builders detail but it should give you an idea of what you'll need. You could also send it to the bank and ask if it is the type of document they want before you fill it out. Just make sure to .pdf print it afterward. (I can help you through that too if you need help. Along with it you will need all of the engineers design for trusses, retaining walls (if req) and other things like plans and quotes for everything that you wan t borrow money for. go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110576 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11039 |
