Browse Forums General Discussion 1 Oct 09, 2010 9:25 pm Our neighbour has their garage slab on their fenceline, their garage is further back than our so we actually get to look out to a brick wall from our dining area!! Anyway, we are doing a garden bed up against their wall and were digging around today. When we starting digging close to the fenceline, we noticed our neighbours builder had done a really sloppy job with their slab pour. To the point where their slab has an overflow of about 35-40cm into our property (it had been simply covered up with soil)! What are our rights in regards to this? Its not part of the slab IMO as its only about 7-10cm thick. How do we get this recified? Can we hire a jackhammer and just knock it off with it? Any advice or ideas are much appreciated! ICK So glad the building is over, never again. Loooove our house, but still not quite sure it was worth all of the stress they put us through! Re: Neighbours slab 2Oct 09, 2010 10:43 pm If its a poor job, a hammer and a lump of steel (chisel) should fix it. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 5019 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 13387 Hi all, Trying to workout the minimum stepdown required between slab for my house and the outdoor alfresco area. Garage is 100mm lower than rest of the house and plan was… 0 3651 |
