Browse Forums General Discussion 1 Oct 07, 2010 8:01 pm I moved into the new place about a month ago now. After coming home last week i noticed someone had used my front water tap. Then the next day the old man was over and he told the the render guys next door were using my tap. Then last Friday i was leaving to go to the airport and found the brickis using the my water. I asked then why they were using it and they told me the site had no tap out the front yet. They also saisd they'd been using mine to do the whole house! I contacted the builders 2 days ago who apologised and were going to get onto the site supervisor to find out what was going on. So 2 days later i still havent heard anything. Whats the best way to go about this, ring again and ask whats going on? Contact the water board? Isn't this classed as stealing? I cant see the differance between this and me using there brick's to build my house. Re: Builders Next Door Using My Water 2Oct 07, 2010 8:38 pm I just read this in the general thread the other day, it has been happening to some else. They came up with some good idea's. Have a look at this thread viewtopic.php?f=1&t=39231 I hope this helps. Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=36205 Land Settled - 19 Jul Site Scrape - 23 Aug Slab - 2 Oct Frame - 27 Oct Locked Out - 1 Dec Handover - 11 Mar Re: Builders Next Door Using My Water 3Oct 07, 2010 8:47 pm Thanks Janelle My situation is different in that the build next door is basically finished, meaning i've footed the bill for the whole damn thing. Like others said though, if i had been asked and compensated for i wouldnt have cared if they'd used the water. Re: Builders Next Door Using My Water 4Oct 07, 2010 8:54 pm Ok I didn't realise they had nearly finished. Maybe contact their builder in regards to some sort of compensation. It is stealing! Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=36205 Land Settled - 19 Jul Site Scrape - 23 Aug Slab - 2 Oct Frame - 27 Oct Locked Out - 1 Dec Handover - 11 Mar Re: Builders Next Door Using My Water 5Oct 07, 2010 8:58 pm Thats what i reckon! i did ring but haven't heard back, i'll try again tomorrow. You can't trust anyone in Pakenham Re: Builders Next Door Using My Water 6Oct 07, 2010 9:00 pm Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=36205 Land Settled - 19 Jul Site Scrape - 23 Aug Slab - 2 Oct Frame - 27 Oct Locked Out - 1 Dec Handover - 11 Mar Re: Builders Next Door Using My Water 7Oct 07, 2010 10:52 pm It's pretty normal. They did the same to me, and to my neighbour. The cost I don't mind (its like 20c for 1000 litres), its just them using without asking - the builder next door even used our front tap while we were home! *******. They should have their own taps organised. Re: Builders Next Door Using My Water 8Oct 07, 2010 11:12 pm how can they not have a tap if the build is nearly complete? i do think its rude. even if the cost is minimal they are paid to organise these things. i would contact the water board, council, and put a sign on your tap stating this is for private use only and coming onto your property is trespassing and charges will be laid if caught to see if that deters. but my experience in building so far is that anything goes When times get tough build a house...Our second build Re: Builders Next Door Using My Water 9Oct 10, 2010 8:51 am I caught the brickie next door using our power. I walked up and unplugged it in the middle of what he was doing and asked him why he wasn't using his own. He was very embarrassed. Re: Builders Next Door Using My Water 10Oct 10, 2010 10:17 am Fallen_Apple I caught the brickie next door using our power. I walked up and unplugged it in the middle of what he was doing and asked him why he wasn't using his own. He was very embarrassed. all too coommon these days that sites arn't powered up ... and hiring/ buying a geni isn't a cost effective method.. I'm not excusing my fellow tradies.. the "use" of water like that is just silly... OP send the builder the bill for use and add 10% Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Builders Next Door Using My Water 11Oct 30, 2010 7:38 pm Got the $50 i asked for and they've put a tap in i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16007 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46013 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20181 |
