Browse Forums General Discussion Re: Easement Consent Letter 2Nov 19, 2007 8:46 pm devank,
Lucky you. I've also been requested to request a drainage easement by the local council. This is because I have "negative cross fall in the footpath". However, if the stormwater drainage pipe is angled at about 45 degrees to the kerb then it becomes a positive cross fall, but I've yet to convince the council of this. The wheels of progress turn slowly. The last page of the linked PDF below, contains a sample letter: www.ryde.nsw.gov.au/WEB/SITE/RESOURCES/ ... ainlow.pdf Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6150 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17138 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16130 |
