Browse Forums General Discussion Re: Residential Land buying guide 2Sep 21, 2010 11:32 am H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: Residential Land buying guide 10Sep 28, 2010 12:27 pm H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: Residential Land buying guide 11Sep 28, 2010 1:02 pm Hi, Check with someone close by to determine what class of slab was required, and if there was much rock that had to be removed. This will give you a rough idea of what your increased site costs are likely to be. As mentioned earlier check the slope of the block. My block has a 1.5 metre slope in it and I need to get a retaining wall built which added just under $7000 to the site costs. Michelle House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland 1 4676 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6445 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24872 |
