Browse Forums General Discussion 1 Sep 18, 2010 9:57 pm Hi guys, I am looking to at my options on building on a parcel I have located in the Hillcroft Estate in South Morang, Victoria. My original idea was to sell this land and buy in an area closer to the city and treat it as an investment property however, I have thought that if I am able to build 2 townhouses (and put both up for rent) on my existing block of land it may be worth holding onto. Only problem is that because the hillcroft estate is somewhat new, I may be restricted to building only 1 dwelling. Within the Section 32 there is an area that reads "the transferee at any time conduct building other than one private dwelling house with the usual outbuildings." Just wondering whether anyone has explored similar opportunities??? and whether there are any exceptions to the rule... even it means building as 'one dwelling' and some how designing it to facilitate 2 tenants. Thanks for any advise that can be shared. Cheers, Spiro Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 I am not based in Victoria however i had a quick look into your question to understand what you were asking. The way I read the regulations, overshadowing relates to the… 1 2233 |
