Browse Forums General Discussion Re: silly question alert.. 2Sep 07, 2010 9:42 am yes it'll definitely fit through the door Have the short end face the door (109x89) end Rotate the sofa 90 degrees (89x109) Now push it in, you will have 10cm to spare It'll be your hallway and corners that you may need to get past I'd be more concerned with Good luck and a nice sofa size indeed Re: silly question alert.. 3Sep 07, 2010 9:51 am thanks its the Plush Melbourne 3 seater http://www.plush.com.au/Collections/Col ... /melbourne i will have to get the guys to walk right round my house and in thru the front deck door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and i have a massive driveway .. they better get a coouple of strong dudes to carry it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9962 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6156 1 13127 |
