Browse Forums General Discussion Re: Help reading engineering drawing.. please ! 5Sep 06, 2010 11:41 am View our blog at: http://room4acubby.blogspot.com/ Re: Help reading engineering drawing.. please ! 7Sep 06, 2010 12:22 pm View our blog at: http://room4acubby.blogspot.com/ Re: Help reading engineering drawing.. please ! 10Sep 11, 2010 1:56 am room4acubby The sewerage cover I think will look like the bit of concrete in the attached photo. It's about 300mm in diameter Closer to a metre in diameter for the total manhole. The covers are around 600, large enough for someone to go down (expanding underground). Cover can be concrete or metal depending upon requirements. Baronox With the Sewer pit, are they open at the top (as it is showing in the picture above) ? Cause then it might be an issue with smell coming from it.. ? They are generally air tight. Its also an enclosed sewage pipe inside at the bottom. Smells wont be a problem. Here are some references I found when we were building to give you an idea whats down there! http://www.actewagl.com.au/water/standa ... rds3b.aspx http://www.actewagl.com.au/publications ... Wss053.pdf http://www.actewagl.com.au/publications ... Wss052.pdf http://www.actewagl.com.au/publications ... Wss057.pdf http://www.actewagl.com.au/publications ... Wss062.pdf Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31850 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14652 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7171 |
