Browse Forums General Discussion 1 Aug 31, 2010 9:01 pm Just wondering if you build a garage on the boundary does the wall need to be constructed of double brick cheers Re: Garage on boundary 2Aug 31, 2010 9:23 pm I think it would depend on where you are and what your particular Council requirements are. Our garage will be on the boundary but it isn't double brick Cheers! Miriam Re: Garage on boundary 4Aug 31, 2010 9:36 pm ^^^^ Ditto Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Garage on boundary 5Sep 01, 2010 9:35 am Our boundary garage is also just single brick, as are all in the area as far as I can tell. With those funny brick columns inside. I still don't know what those are for. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Garage on boundary 6Sep 01, 2010 9:42 am Quote: Our boundary garage is also just single brick, as are all in the area as far as I can tell. With those funny brick columns inside. I still don't know what those are for. That is called a revealed brick wall. The columns are for support. There will be metal sections within the mortar that tie the columns to the main wall. Cheers Re: Garage on boundary 9Sep 01, 2010 3:08 pm brick venneer here also. But as we cut down below the joining land and werent sure of their levels, the builder put in a concrete upstand. Our home: viewtopic.php?f=31&t=29960 Re: Garage on boundary 11Sep 01, 2010 5:14 pm Unless a "higher authority" says so, a Garage wall on the boundary does not need to built with a double brick construction. I have single brick + piers as is the 'minimum' required. But unless you particularly ask for it, or it could be an 'engineer's request', then a double brick wall to a garage on the boundary (with no first floor loads over) would be overkill and a waste of money and space. Re: Garage on boundary 13Sep 02, 2010 8:05 am Gambarol Quote: Our boundary garage is also just single brick, as are all in the area as far as I can tell. With those funny brick columns inside. I still don't know what those are for. That is called a revealed brick wall. The columns are for support. There will be metal sections within the mortar that tie the columns to the main wall. Cheers Thanks for explaining that I had seen the bits of metal sticking out while it was built and had wondered about them too. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Garage on boundary 14Sep 03, 2010 4:17 am btherl Our boundary garage is also just single brick, as are all in the area as far as I can tell. With those funny brick columns inside. I still don't know what those are for. They hold up the roof and support the wall. Not sure if you have ever noticed but on a brick veneer house the brick does not form any of the structure, all it is is a lining and the support is done by the wall frames. Now head to the garage, and if you have a single brick wall and no frame then you need something to hold the roof up hence the support columns. If you have a close look you will probably find a beam parallel to the wall sitting on top. Re: Garage on boundary 16Sep 07, 2010 12:04 pm Missing Link Just wondering if you build a garage on the boundary does the wall need to be constructed of double brick cheers Not necessary. You could have sevral options: (1) Brick veneer (2) Double brick (3) Single brick with columns Suburbia is where the developer bulldozes out the trees, then names the streets after them. thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16268 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17155 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7062 |
