Browse Forums General Discussion 1 Aug 17, 2010 9:21 pm Hi All, Considering building with Clarendon Homes in Sutherland Shire, NSW. Looking strongly at the Waterfall with the Abbotsbury facade. Was wondering if any other people out there have built this particular home with hopefully this facade. If so then some thoughts on the house and building process would be much appreciated. Brick selection is giving us a particular headache as the inclusive bricks are very basic and the upgraded ones are pricey. Also need information on the buiding process, length of time that Clarendon took? any problems encountered? build quality et etc . Thanks in Advance. 2233 Re: Building with Clarendon in Sutherland Shire NSW. Info Pl 2Aug 20, 2010 7:17 am Hi Gav, Not sure if you have had a read of the thread's but both themax, justcamping and Helldad have built with Clarendon recently. I'm not sure of the designs they built. Have a read here viewtopic.php?f=31&t=20717&p=532081&hilit=decal#p532081 viewtopic.php?f=31&t=10891 These are the ones I can find quickly for you. Still not in. Don't ask!? Re: Building with Clarendon in Sutherland Shire NSW. Info Pl 4Aug 20, 2010 8:28 pm Thanks for that Info and had a look through their posts, however no Waterfalls with the Abbotsbury facade. Would really like some picts and other info about the Waterfall especially brick selection etc etc. Did anybody have any problems with Stormwater run off, did Sutherland Council give you grief. gav2233 Re: Building with Clarendon in Sutherland Shire NSW. Info Pl 5Aug 23, 2010 6:17 pm Regarding Sutherland council giving anybody grief: if your block is covered by the new statewide housing code, they can't give you much grief or happiness. The only approval I needed from them was for the driveway alignment (I changed the location of the driveway) which was problem-free if you don't count the 6 long weeks for a single bit of paper. A friend built recently here in the Shire through the local building code and I believe she was quite pleased with her interactions with council. Regarding stormwater, you will probably need a hydraulic engineer's report as part of the approval process, and he or she will probably require all sorts of drainage works, so allow $8000 or so for that if Clarendon don't include it. Re: Building with Clarendon in Sutherland Shire NSW. Info Pl 6Aug 23, 2010 9:12 pm Here is another link for people building the Waterfall or at least with Clarendon viewtopic.php?f=31&t=25578&hilit=clarendon+waterfall edit Sorry - just realised you've already posted on that thread - so you already know about it Never argue with an idiot they drag you down to their level & then beat you with experience - Dilbert View Thread: viewtopic.php?f=31&t=19733 Contract signed 14Sept Slab 30Sept Bricks laid 1Dec Lock up 26Feb Keys 10Jun Re: Building with Clarendon in Sutherland Shire NSW. Info Pl 7Aug 24, 2010 2:14 pm Hi JXH, Yes the block is covered by the states housing code which would allow me to build under a CDC, however Clarendon in their wisdom have decided not to use Complying Development Certificates but to go to council with a DA. When asked why they give various reasons but I think the main reason is they can sell you more stuff, using the council regulations as an excuse. A typical example is wall articulation, required under council but not required under a CDC. Yet Clarendon is happy to charge you about 6000k for it. Plus, landscape plans and enviromental statements, all not required for a CDC but required for a council DA, and they all cost money. Yes, Clarendon have mentioned the soakage pit in the back for stormwater run off but they have said it depends on the Hydraulics report. If it can go to the street then that will be removed. (Hint, if buying a block to build on buy on the high side of the street.) Still require any info on the Waterfall with the Abbotsbury facade, were you happy with the results and waht bricks did you pick. Gav2233 the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6747 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 having built on acres several times i suggest that you also need to add the cost of a sewerage system and any associated fencing, water tanks with associated extra… 2 1075 |
