Browse Forums General Discussion 1 Nov 05, 2007 3:48 pm Hi,I want to renovate an old laundry, the walls are sandstone (foundations) and are dusty and crumbling somewhat. I like the look but not the dust and mess. To achieve a cleaner enviroment can I seal the walls with a clear paint/sealer? Also it has 3 old fashioned cement wash basins. Can they be rejuvenated?Thank you(new member) Re: laundry renovation 2Nov 05, 2007 3:50 pm Can you possibly upload a photo so that we can have a look at your laundry? Re: laundry renovation 3Nov 05, 2007 7:02 pm Cfoulsh….it wont be a problem sealing the sandstone, but you will need to give them a good wash down first. Probably with a Gurney if you can get one.
Once they are dry, you can get a sealant from the hardware shop and paint it on. As for your Tubs….not sure about those. Welcome also!!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: laundry renovation 4Nov 05, 2007 7:20 pm Just be careful they are not crumbling due to rising damp - - ie salt - or sealing it could lock the water in and make it travel further up the wall.
Where is the house ? ie which state? And you can paint the cement tubs with paint if you like to jazz them up. steve This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 13583 Agreed. I just found out today the certifier has not given the final sign off. 2 4192 Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added… 0 14223 |
