Browse Forums General Discussion 1 Aug 09, 2010 8:20 pm I am going mad! I'm trying to work out whether or not we can afford to demolish and rebuild, but it's hard to get an idea of what the build cost will be without plans, and I don't want to spend $40,000 or so having plans drawn up if there's not a chance we can afford to build. In the area we're in - and with our skinny block - it would not make sense to use a project home builder. I can't see a designer who isn't an architect coming up with something we'll like either. The first builder I spoke to said he thought it would come in at abou $2,600 per square metre to build something architect-designed and fairly fancy but not over the top, while the architect I want to use reckons more like $3,700 per square metre. So, does anyone reckon we can build a two-storey architect-designed home for $2,600 per square metre (or less preferably) or am I dreaming? I am not wanting super-schmick finishes, but I suspect when it comes down to it I'll want floor to ceiling windows and other expensive things. Alternatively, would a group like Inform Design be worth considering or are they going to be just as expensive? Re: Cost per square metre - architect designed home in Melbo 2Aug 09, 2010 8:35 pm What are your block dimensions melbmeg? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Cost per square metre - architect designed home in Melbo 3Aug 09, 2010 8:47 pm Also, do you have any heritage issues or would this be a complete new build? Renovation Thread: viewtopic.php?f=31&t=38489 Re: Cost per square metre - architect designed home in Melbo 4Aug 09, 2010 9:12 pm Thanks for responding, guys. New build. Block dimensions are 15m x 35m but we want to build two townhouses so Mum can live next door. (They don't have to be even in size though). No heritage overlay (phew!) but the council has basically told us to get good architect because they are more likely to approve a sophisticated and progressive design. Re: Cost per square metre - architect designed home in Melbo 5Aug 10, 2010 2:46 am IMO, $2,600 per square meter can be done but nice fittings (i.e non standard) will up that price rapidly. For example, floor to ceiling windows. Re: Cost per square metre - architect designed home in Melbo 6Aug 10, 2010 7:14 am why dont you pm nathan budde (he is on this forum, did the 'custom design' thread and a few others, his web is in his signature ) he might be able to give you a good idea re costs, or at least get you a sketch drawn up that you could take to get rough quotes. He is not that expensive (well not 40k expensive) this is his website http://www.buddedesign.com/ his prices are on it. good luck. hope you can do it within your budget. Re: Cost per square metre - architect designed home in Melbo 7Aug 10, 2010 6:21 pm [quote="melbmeg"] The first builder I spoke to said he thought it would come in at abou $2,600 per square metre to build something architect-designed and fairly fancy but not over the top, while the architect I want to use reckons more like $3,700 per square metre. quote] Based on your figures and assuming a home size of 35sq (325sqm) then house costs are $845K (2600 /sqm) $1.2M (3700 / sqm) This puts you into high end territory regarding builders, typically Inform & Comdain, etc will be around $600-800K. Re: Cost per square metre - architect designed home in Melbo 9Aug 10, 2010 11:33 pm Wow is Melbourne that much more expensive than Sydney? We're building an architect-designed house in the Sydney Hills area. I admit it's nothing fancy, certainly no floor-to-ceiling windows, but it's definitely not project home either. For the house itself (including floor coverings, but excluding any landscaping) came to about mid $1,600 per sqm. House is roughly 475 sqm (about 51 squares I believe). $2,000 per sqm here will get you that little bit fancier design (more windows, balconies etc.). But $3,000 and up? That's really expensive! Re: Cost per square metre - architect designed home in Melbo 10Aug 10, 2010 11:37 pm Kitty, do those 1.6k include all architects' fees, dev application to council etc.?? I think that's more like it (the cost). BTW, did you have to demolish first? My signature is distracting people from my wise posts ... Re: Cost per square metre - architect designed home in Melbo 11Aug 10, 2010 11:58 pm Ah that's right: my figures do NOT include architect fees and all that. If I were to add up all those on top of my head now (architect fee, engineering fee, survey fee, council fee) they are about $20,000. Per square meter, add about $42 on top of the $1,600-ish, so let's just say $1,700 plus. Bear in mind though (at least in my area here) there are roughly three "tiers" of builders. The top tier is about 20% more expensive than the middle tier (where I am). The bottom is say about 10-15% less expensive than middle. Having said that, this is all relative-speak of course. The bottom tier, at about $1,500 per sqm, would still be significantly more expensive than your typical project home builders. No demolition fee, it was a blank piece of canvas with little elevation (about 1.5-2 meters from lowest to highest ground). Re: Cost per square metre - architect designed home in Melbo 12Aug 11, 2010 12:04 am Yep, more than double or thereabouts ... How are you finding the building experience? How far are you into the build? Do you have a single point of contact and do you have access to the house at any time (so you can inspect work and demand fixes etc.)? I don't think I've seen an 'architect' designed thread (maybe I wasn't aware of it ) ... so can't compare the practices ... My signature is distracting people from my wise posts ... Re: Cost per square metre - architect designed home in Melbo 13Aug 11, 2010 12:17 am We're not very far into this, only the slab has been poured so far. The journey so far has been nothing but painless! Big credit goes to our chosen builder though; he (yup, single point of contact) is accommodating and 'transparent'. For example, to design our kitchen, he sent us off to his supplier and we dealt directly with them. We also went window shopping on our own for the silliest items like toilet holder or taps, told him what we wanted, he gave us his prices vs what's been allowed. We've changed inclusions like, 3-4 times already I think... I went to the site only TWICE since work began, he pretty much just went about his business unsupervised. Re: Cost per square metre - architect designed home in Melbo 14Aug 11, 2010 12:23 am Sounds good! Good luck with the rest of the build! Any chance of starting a thread or a blog (as mentioned, haven't see a designer build yet :shock: )? My signature is distracting people from my wise posts ... Re: Cost per square metre - architect designed home in Melbo 15Aug 11, 2010 12:33 am Thanks! Yeah maybe we'll do a thread when things get more interesting! Re: Cost per square metre - architect designed home in Melbo 16Aug 11, 2010 6:42 am Lex Yep, more than double or thereabouts ... How are you finding the building experience? How far are you into the build? Do you have a single point of contact and do you have access to the house at any time (so you can inspect work and demand fixes etc.)? I don't think I've seen an 'architect' designed thread (maybe I wasn't aware of it ) ... so can't compare the practices ... Hi Lex There are several architect designed threads in homeone but they were probably a year ago. My house is one of those as well as Mek, ladyice (I think) and at the moment the most stunning home of Michelle (chelle) in Tasmania. I know there are many more here, just cant think of them so early in the morning. Hopefully somebody can find you the links. Mrs B Re: Cost per square metre - architect designed home in Melbo 17Aug 11, 2010 6:47 am Here we are...chelle's architect designed home, I love it, unique, individual and purpose built to take in the views. http://people-in-glass-houses.blogspot.com/ Mrs B Re: Cost per square metre - architect designed home in Melbo 18Aug 11, 2010 8:56 am Thanks, MrsB! See, that's what I meant by 'not aware' - I think I wasn't paying attention to this "little detail" long time ago when I was walking thru your blog ... thanks for pointing that out and for the other info - that house in the link is spectacular!! I'm also more interested to learn about the relationship, "rules" and the building process itself, the paper-ology (what kind of contracts etc), builder's admin etc. because ATM I pretty much know what to expect from a project builder, but all these other-than-the-house-itself things are also a major factor. If clients are treated and de-powered in a similar way like with some project builds, then it wouldn't be good, especially considering the 2- or 3-fold price. My signature is distracting people from my wise posts ... Re: Cost per square metre - architect designed home in Melbo 19Aug 11, 2010 12:12 pm Hi guys here is an earlier thread regarding custom design costs and site costings. viewtopic.php?f=31&t=28067 Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Cost per square metre - architect designed home in Melbo 20Aug 11, 2010 12:47 pm Thought I might give you some info on the house I’m starting to build in oct. 580sqm block in mernda villages Custom designed house 251sqm includes double garage. 4 bedrooms at the front of the house with a home theater upstairs. 3 meter glass hallway separating bedrooms and living at the back of the house. Raked ceilings in home theater, living room and alfresco. Massive kitchen HIMAC bench tops, 4 sets of French doors some, funky windows, 600 x 600 polished porcelain everywhere except HT and bedrooms. Upgraded carpet, 900mil appliances, colourbond roof. Most of the house is cladding and render with some brick in different places. It's a very architectural house. Design permits ect were 4k house is 230k Hope this helps ,Mark 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3603 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6174 Your build is relatively simple, I believe your job can be easily done by a good building designer, you really do not need to pay for the architect. Remember, architect's… 3 10989 |
