Browse Forums General Discussion 1 Nov 04, 2007 9:03 pm Over the last year we have developed a leak on our verandah, it only happens after extended, not necessarily heavy rain and occurs between the facia on the gutter as drips. Usually only over half a metre or so, but over 4 -5 metres this weekend.
The verandah roof is an add on, so it's colour bond roof into matching gutter, then a poly carb roof for the verandah. The poly carb has been up for 8 years and is flashed back into the gutter. Our main roof is colour bond, pitched at 12.5 degrees, the section where it meets the gutter is about 15 years old although the guttering is 25 years old, it seems to be in original condition with no holes and the down pipe doesn't appear to be backing up. Anyone with a suggestion? Regards, Mick Re: Leak between fascia and gutter 2Nov 04, 2007 9:11 pm Hi,
If guttering is 25 years old, I'd suggest having a roofing plumber inspect it all and advise what needs to be done. If he advises repairs or replacement, get him to show you the defective bits. Cheers! Ash. Re: Leak between fascia and gutter 3Nov 05, 2007 7:08 pm Mick47….like our bodies……housing selections wear out as well!
I agree with Ash, get in someone, probably a plumber to inspect your roof. He will be able to tell you what’s going on. Good luck! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Leak between fascia and gutter 4Nov 05, 2007 7:17 pm It's possible the fall of the gutter is not enough in that section and the water is backing up a bit and overflowing over the back edge - hence why it did it more the last weekend. either pop up and a have a look yourself, run a string line underneath it to sss if it's sagging, or as said above - have it looked at.
and hey Mish Quote: Like our bodies……housing selections wear out as well! Do you mean they start dripping and sagging too Noooooooo !!! That's years away !!!!!! Steve edit for typo Re: Leak between fascia and gutter 5Nov 05, 2007 7:21 pm Actually… what you need to watch is if the water is back filling INTO your internal walls.
This can happen often, and if it’s not sorted, you could end up with a mess internally as well. That’s why a plumber is best…..sorry Steve! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Leak between fascia and gutter 7Nov 06, 2007 7:23 pm Yak_Chat It's possible the fall of the gutter is not enough in that section and the water is backing up a bit and overflowing over the back edge - hence why it did it more the last weekend. either pop up and a have a look yourself, run a string line underneath it to sss if it's sagging, or as said above - have it looked at. and hey Mish Quote: Like our bodies……housing selections wear out as well! Do you mean they start dripping and sagging too Noooooooo !!! That's years away !!!!!! Steve edit for typo Missed that one Steve….not sure about your body, but mine is sagging in some places! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20239 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17325 |
