Browse Forums General Discussion Re: possible building dispute 21Aug 02, 2010 8:44 am It would not hurt to start a file with them. The more documentation and paper trail you leave the better it is for you, even if nothing goes wrong in the end. But if things do go pear shaped then you can say well look here I rang at xx/xx/xxxx and so and so told me, then they will say oh yes here we go we have notes.. Just in case. yes it does, you've just not understood it. theres a difference. 4 5322 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6636 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 |
