Hi,
If putting in something like a Rinnai Continuous flow hot water system what is the recommended maximum distance to your bathroom/laundry before you should consider putting in the heat pump unit to pre-heat water in pipes ?
Is there a standard rule of thumb along the lines of "wait 1 second for hot water for every meter of pipe"
from the heater ?
