Browse Forums General Discussion 1 Jul 16, 2010 1:22 pm Hi we have a house thats looking over city lights at night. we are having 6.38mm laminated glass windows (there is a lot of them) we have to decide between clear and grey comfort tone (just the simple grey tone float glass, no special films or coatings ) The glazier said shouldnt effect us looking out at night to city lights but a friend said they thought it could and Im not sure if thats the case thanks Mike Mike 2/3 of the way thru the build Re: grey comfort tone glass - advice 2Jul 16, 2010 5:57 pm MJAB Hi we have a house thats looking over city lights at night. we are having 6.38mm laminated glass windows (there is a lot of them) we have to decide between clear and grey comfort tone (just the simple grey tone float glass, no special films or coatings ) The glazier said shouldnt effect us looking out at night to city lights but a friend said they thought it could and Im not sure if thats the case thanks Mike Grey vs Clear... Your grey will make a small difference at night and you will really only notice it at dusk, just as the lights appear. When full darkness swings in you won't see any difference. Borrow a free sample from your supplier and try it. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: grey comfort tone glass - advice 3Jul 16, 2010 7:18 pm HI thanks for that reply Ed shouldnt the reverse occur internally if you have your internal lights on , (that same reflectance property making it harder to see in in daylight from outside ) so its more reflectant to look out at night obscuring the view ???? Mike Mike 2/3 of the way thru the build Re: grey comfort tone glass - advice 4Jul 16, 2010 7:40 pm MJAB HI thanks for that reply Ed shouldnt the reverse occur internally if you have your internal lights on , (that same reflectance property making it harder to see in in daylight from outside ) so its more reflectant to look out at night obscuring the view ???? Mike Tinted glass acts like a mirror for the brighter lit side. If you've ever ridden a bus or train at night you can see outside, but only the actual bright lights are really visible through the bright reflection of the interior, the detail in the low lit areas outside is gone. If you want to see a view, rather than just the bright lights, stick to clear. Looking inside from outside on a dark night is very difficult until you turn any inside light "on". Then everything inside is visible. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18217 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39049 |
