Browse Forums General Discussion Re: Reusing old timber 6Oct 26, 2007 6:48 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Reusing old timber 13Oct 31, 2007 8:31 pm Al Using Merbau I'm resigned to predrilling each hole anyway. So what's another 20mm deeper per hole It is more time-consuming with hardwood joists as apposed to t/pine. When you drill and countersink the hole in your decking board, the board must be in the exact position over the joist where it will be fixed. Also you should not be using shorter than 50mm screws or nails, so its 30mm into joist. Hi, We want to reuse the water for our veggie garden (we're basically using 250L / day for that – so if I can grab some from the bioseptic, it would help us a… 0 2858 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
