Browse Forums General Discussion Re: new downlight fitting 12Nov 13, 2007 10:42 am How did you go with this?
Technically, an electrician isn't required to change the "gimble" (frame) of the downlight, as it's no different to changing a globe (because the frame isn't connected to any live electrical wires; they're connected to the transformer a short distance away). Be aware that some frames have mounting brackets for the transformer, which would need to be unclipped. If the electrician has done his job properly, there shouldn't be any exposed single insulated wires going into the transformer, and you are safe to touch/move the transformer. Double insulation is required to be continuous all the way into the transformer terminal cover. If you see any coloured wires, then they are the single-insulated wires. You are correct; adjustable gimbles are usually larger diameter than fixed ones. You'd need to make sure you aren't likely to cut or damage any of the wiring that is in the roof space when you make the hole bigger. The insulation problems have already been mentioned so I wont elaborate. The other thing to watch out for is around the hole there might be timber (which the gyprock is attached to) which may prevent (or make more difficult) you making the hole larger in the direction you want to go. A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6681 Is there a building permit? RU in Victoria? What is the value of the building contract? 1 6787 |
