Browse Forums General Discussion Re: White set plaster 2Oct 20, 2007 7:13 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: White set plaster 4Oct 20, 2007 7:43 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: White set plaster 13Oct 22, 2007 9:32 pm Casa2 I've been thinking about my question more and have come to the realisation that I'm probably asking the wrong questioon. The only reason I'm considering white set plaster is with regard to chasing in extra wiring or plumbing in the future and then putting the re-rendering so that it still looks good. So my real question should be: - With cement render, is it possible to cut into it then re-render the cut section and make it look good? There must be someone out there that does cement rendering for a living. Cheers, Casa of course its possible, just do it right!, blending takes time, you cant just slop some filler over it and give it a lick of paint, you need to give it the same amount of care you would with any other plaster job. mind you, its a lot easier to just run yours wired on the external double brick cavity!, no cutting of bricks required. Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14278 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5037 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5300 |
