Browse Forums General Discussion 1 Jun 20, 2010 1:42 am Hi All,
We have bought a house and have been tinkering with some preliminary plans for a renovation. These are preliminary and we will get plans drawn up professionally - although at this stage not sure if we should go to a builder's draftsperson or to an architect - your thoughts on this would be welcome. Attached is the original layout, then my draft for the downstairs and finally a draft for the proposed upstairs renpovation. I would really appreciate your comments on these drafts. Many thanks in advance. Original Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ New - downstairs Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ New - upstairs (note the upstairs bed/bath/study will be over the garage and the decking will extend to the far wall of bedroom 3 and the kitchen/pantry wall - which I understand are load bearing). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Appreciate your thoughts on rennovation plans - thanks 2Jun 20, 2010 3:34 am Hi =) Your plans are very feint and hard to see, so I've taken the liberty of grabbing your originals and recreating the bottom floor for you, although have slightly reworked the kitchen and pantry. It felt a little squishy as it was, so I switched the way that it faces. This puts the pantry against the front window, and you may not want that, so feel free to ignore. I just felt that this gives you a greater feeling of spaciousness inside the house (to the detriment of the facade, but that can be covered with good gardening ideas Either way, this should give others an idea of what your plans involve =) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'll take a better look at it when it's not 3am and my brain is working =) Overall, nice work! Re: Appreciate your thoughts on rennovation plans - thanks 3Jun 20, 2010 3:53 am Somewoman, That is extremely kind of you - what is the software you used to do that? Thanks for the suggestions - this is exactly what I am after - a 'critical friend' or two. I like your idea with the kitchen. The only issue is that we have a great view out that kitchen window, but i definately like the island bench design and I agree yours is a better layout. Again many thanks - if you get another chance to have a look and have anymore ideas they will be gratefully recieved. Re: Appreciate your thoughts on renovation plans - thanks 4Jun 20, 2010 11:58 am I feared you would say as much (about the view) =) So realistically you want to maximise what looks out at that side of the house, but still have the through section going out to your back pergola. Would the budget stretch to moving the bed and bath over to the left side of the house (where the family room currently is) and just opening up that entire area for family and dining and kitchen with awesome views both ways? You would lose your two-way fireplace in doing so... But you may feel it is worth it in other gains. Thoughts? Re: Appreciate your thoughts on renovation plans - thanks 5Jun 21, 2010 1:46 am Someowoman, We were hoping to keep the plumbing where it was to keep the cost down and my other consideration is around re-sale down the track - by leaving the snug as is, it could be sold as a potential 4th bedroom. But it is definately worth considering if the kitchen is too cumbersome. I have also mocked up some easier to view plans and added to my free hand plan above. I tell you, once you start mucking around with that floor planner software it is absolutely addictive. Now - if only I can afford all the furniture I have added around the house Re: Appreciate your thoughts on renovation plans - thanks 7Jun 21, 2010 9:53 am It looks a lot more open now that you have done it that way - it looked like a wall enclosing the kitchen from the entrance before. Personally, I don't mind the kitchen being near the entry. I think you have enough space there that it works - you're not walking through the kitchen when you come in the front door. You WILL see any mess when you come in the door, but then many people just don't have mess in their kitchens so it's not always an issue. If you feel like d@n and want to close it off a little, you could always put like a 1m wall from the entry into the room with a hole through it. It would allow you to make the entry feel more like an entry, give you somewhere to put a nice vase of flowers or candelabra (or something funky to decorate), and still see through it so that the space feels larger and more open. I really like what you've done =) Re: Appreciate your thoughts on renovation plans - thanks 8Jun 22, 2010 1:04 am Many thanks for your comments. Yes, I am unsure about the entry - that is a major point I have reservations over. When you say extend at the front, do you mean pull the entry area, up to the kitchen, out to the end of the bedroom there? I could leave the entry how it was, but I also really want that WIR and use it also as a place for visitors to hang their coats. Bit stuck on the entry questions to be honest - no, I am not entirely happy with it but can't work out what else to do. The pantry will also have a sliding door - I just couldn't figure out how to put one in on the software. Any comments on the upstairs deck - does that look doable. The dowstairs roof is metal cliplock sheeting (almost flat but has a slight pitch). Re: Appreciate your thoughts on renovation plans - thanks 10Jun 22, 2010 1:08 pm I like what D@n has done with the layout. But i would think about swapping the bedroom and bathroom. I just wouldn't want someone having to walk past the bedroom to go to the bathroom. And then you could have the doorway to the bedroom at the end of the hall which would give a little more space to the bedroom. Hope that makes sense... Re: Renovation floorplans - your thoughts?? 11Jun 23, 2010 2:17 pm D@n - thanks so much. I like what you've done - just need to weight up losing the view in the kitchen/living, but I do like what you've done. Izzehz - makes complete sense. Pull the door out to be flush with the bathroom wall. Godd thinking 99. Another question I have, which may be better in new post, is under floor heating. I will search the forum as well, but coudln't seem to find much on it when I googled. Thanks all for your constructive feedback Gus Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 27904 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5567 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3513 |
