Browse Forums General Discussion 1 Jun 18, 2010 10:37 am Hey All, I have had to change my plans from Slab to Stumps. I already signed a contract with the builder. The better has advised yet if this will change the costings. Anyone had this? Does anyone know would stumps be more expensive? Thanks Re: Change from Slab to Stumps 3Jun 18, 2010 1:42 pm Yes for sure. I am building on stumps and was more expensive. You have to factor in all of the extra bricks it is going to to take depending on how high the piers are- for the piers and also around your sub floor, the footings, your flooring and the fact you will most likely have stairs. Your build time will of course be longer for all of the extra work they have to do so more labour costs. Lisa- Finally in our house!!! Re: Change from Slab to Stumps 4Jun 18, 2010 10:49 pm Depends on the block you are building on, so its a case by case. It was cheaper for us on a slopping site to use combination of stumps & slab to save on retaining costs. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys If you're in a flood zone, not only are you dealing with the importation of fill and laying it down in 150 lifts to achieve compaction, you're going to have to consider… 4 5533 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6942 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35326 |
