Browse Forums General Discussion 1 Jun 17, 2010 1:01 am quick question i'm using the plasterboards you get from bunnings to put up walls i've nailed them in, i've joined up the cracks and i've sanded it down. do i need to put any sealer/plaster on it? or can i just go with undercoat and 2 coats paint? its for a small room (was a garage, not a pool room) thanks will uploads picts soon If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8302 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6149 i would not be signing anything on the day read your contract about when builder submits final invoice generally, have to meet builder within 7 days of receiving final… 1 4729 |
