Browse Forums General Discussion Re: PDF not allowed? 2Jun 01, 2010 12:38 pm Either host it on your online files that most ISP's give you. Or convert the .pdf to a .jpg. 2 4467 The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 8595 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 4811 |
