Browse Forums General Discussion Re: Alfresco slab after handover? 2May 26, 2010 8:06 pm 180 per cube is a pretty standard rate.. add to that crushed rock and reo if you want it in there. what are your plans with the alfresco long term? Re: Alfresco slab after handover? 6May 26, 2010 8:20 pm Is that for 25 MPA Concrete? Here 25MPA is around $170 a cube - so 180 is reasonable. If the reo is free - do it. I wouldn't pour concrete without reo. Re: Alfresco slab after handover? 8May 26, 2010 9:21 pm Personally I think it would be better done with your original slab if you can. I had cause to ring our Engineer who did the site/soil test and slab design, originally we had the strip footings for our alfresco the engineer strongly suggested we get it integrated with the slab as this is now what they recommend to all as are starting to have problems with strip footings over time cracking/moving etc. I did upgrade to this I think off the top of my head it was an extra $600. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5260 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4251 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 5051 |
