Browse Forums General Discussion 1 Oct 10, 2007 3:37 pm We have an oldish tired looking property and thought that rendering the front would spruce it up a fair bit and make it look alot nice..
Does anyone have any recommendations for renderers in Adelaide, and any sort of indication as to what sort of pricing I should be looking at (ie - do they charge by the m2??) Here's the frontage that we want rendered - not sure how many m2... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rendering front of house 3Oct 10, 2007 3:40 pm What about Moroka?
I think it's a bit cheaper than cement render and won't crack as easily (because it's a flexible product) http://www.kellymoroka.com/default.htm Re: Rendering front of house 4Oct 10, 2007 3:47 pm What a PERFECT fixer-uper!!!!
I would be getting quotes from renderers….no one in here will be able to give you a close estimate. So move onto the serious business of getting your pricings. Then you will know what you are up for. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Rendering front of house 5Oct 10, 2007 3:51 pm Michelle What a PERFECT fixer-uper!!!! I would be getting quotes from renderers….no one in here will be able to give you a close estimate. So move onto the serious business of getting your pricings. Then you will know what you are up for. Yeah it is nearly 40 years old but has so much potential inside and out.. I think rendering the front, and maybe respraying the roof tiles will make a dramatic change to the way it looks.. Re: Rendering front of house 6Oct 10, 2007 4:00 pm I was going to suggest the roof but I didn’t want to be pushy…….for once!!!
Get a quote for - 1) Render – Front 2) Render – ALL 3) Roofing – Re-spray 4) Painting – Timberwork That should pretty much give you a new look externally! I will help you with your colours......??? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Rendering front of house 7Oct 10, 2007 4:05 pm Thanks very much Michelle..
I think there is definitely potential to make it a standout property.. We have just recently had the carport struts replaced with powder coated steel, so it looks much better than in the photos.. The other thought we had was continuing the driveway into a full semi circle to allow drive through access (depending on the budget).. We just splurged on a new spa so will see what kind of quotes we get.. What colour render and roof tiles would you suggest?? (my wide thinks dark gray roof but I'm not convinced!!) Re: Rendering front of house 8Oct 10, 2007 4:55 pm If you want to do it yourself there is a rendering paint that goes straight on over the bricks you can get it at bunnings and other home hardware and paint places. It goes on in 2 coats and $10L will cost you about $100, i think from memory it covers abot 30m2 have used it before is very simple and easy,
If you want to do it yourself Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Rendering front of house 9Oct 10, 2007 5:17 pm McReidy Thanks very much Michelle.. I think there is definitely potential to make it a standout property.. We have just recently had the carport struts replaced with powder coated steel, so it looks much better than in the photos.. The other thought we had was continuing the driveway into a full semi circle to allow drive through access (depending on the budget).. We just splurged on a new spa so will see what kind of quotes we get.. What colour render and roof tiles would you suggest?? (my wide thinks dark gray roof but I'm not convinced!!) McReidy, It's not recommended to call, your wife, your wide. Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Rendering front of house 11Oct 10, 2007 5:48 pm McReidy…I HOPE you meant to type WIFE….not WIDE, hope she doesn’t read your post!!!!
Oh, I see Casa beat me to it! Hahahahahah I actually can see a grey roof! Can’t see your windows due to the roller privacy blinds….what colour are they? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4890 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7493 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5228 |
