Browse Forums General Discussion 1 May 25, 2010 6:31 pm Hi, I have a steeply sloping block (slopes towards the road) and am finally contemplating a build. Given the slope I am considering lightweight construction with minimal site disturbance if possible. Others on the same street have built with full conrete / brick and required extensive expensive site prep. I want to keep cost down and also retain as much existing vegetation as possible. Can anyone give me an idea of cost ($/sq meter) for steel framed home with contemporary cladding and standard fitout (not basic and not expensive). I will not take the owner builder approach, will probably use an architect for design to make best use of the site. Also - I saw a technique in the UK called micro-piling. It was originally developed to stabilise railway embankments but has been adopted for home building. Has anyone experience of using this technique for foundations / piers? I reckon this will be the first of many posts Rgds Locky Re: Approx cost of steel or timber framed home 2May 26, 2010 10:56 am I strongly advise you see someone such as a builder or building company to get you a quote. So many variables. If I say $15k per sqm and you allow for that, then it turns out double then who are you going to get ** off at, me? Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14435 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5358 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16252 |
