Browse Forums General Discussion 1 May 23, 2010 2:26 pm Hi, I am DIY-ing up an end apartment (1 common wall + ceiling & floor) and I need to redo the floor and ceiling, and want as much sound proofing as possible; am going to put some acoustic isolation to common wall. I've just removed vermiculite from the ceiling and was planning to replace it with plasterboard (acoustic mounts+insulation/furring channel); and am considering 14mm floating floor with 5mm acoustic underlay. The bare floor-to-ceiling height is 2450, so I figure I've only got 50mm to work with. I checked out using standard materials for ceiling and it goes 11mm under the 2400 limit. What would be my best option for doing the ceiling with max sound proofing? TIA B Re: Sound insulation with limited height 2May 28, 2010 9:07 pm G'day beeble, Mate CSR make a plaster board called soundchek deigned for noise supression available in 10mm & 13mm not sure on overall sizes just go to their website and submit an iquiry, www.gyprock.com.au Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7472 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31157 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7742 |
